Should make an instagram account for your car.
I got idea for the account name.
bmw1jzparking
*cabut*
sad die me
bmw1jzparking
*cabut*
At least bmw1jzcoming is better.....hhahahhaha
wow from buy evo to buy bmw
Add a starting relay ?Latest update - not enough power is going to the starter. Direct power to the starter and the car fires up, on its own using the battery it won't ignite. Sigh,
Technically it's a Toyota. The only BMW part of this car is the shell.
But wasn't it fine earlier on, before this problem came up?Latest update - not enough power is going to the starter. Direct power to the starter and the car fires up, on its own using the battery it won't ignite. Sigh,
I already have one. Mech friend is helping to checkAdd a starting relay ?
your ignition could be weak.
Yeah, it was. That's the weird part.But wasn't it fine earlier on, before this problem came up?
Nope.Would it start if jump started from another car?
Now that's really wierd but in a way, it's also good since it rules out some other issues. Since it can be started directly, I guess you need to look at last mile cabling to the starterNope.
Weleh, never ending problems!
Owner would like it jinx in that manner......hahhahhahhahahashhhh don't jinx it. its not problems, its maintenance for showroom car.
just because its a showroom car doesn't mean you don't have to replace the rubber parts, the wires -- oxidizes, etc.
cibai....shhhh don't jinx it. its not problems, its maintenance for showroom car.
Please put an air filter on your intake, else your turbo fins will eventually be destroyed. I speak from experience.
Here is the thing, i am little bit confused with the air intake routes. Some put air filter in front of Turbo and some put it separate from the turbo like a factory airbox setup. I know its depending on design but mind to share what's the logic behind both setups. Nothing on google showed me anything concrete so far.
long as its before the turbo, makes little diference…Here is the thing, i am little bit confused with the air intake routes. Some put air filter in front of Turbo and some put it separate from the turbo like a factory airbox setup. I know its depending on design but mind to share what's the logic behind both setups. Nothing on google showed me anything concrete so far.
:driver...
