start a new thread on your build. good to shareMy mod list & shipping invoice as attached as below.
the quiet side la. All my exhaust setup done have been quiet without power loss. So if you're the type who likes to announce you've arrived 4 blocks away, then my setup may not be for you. hahahahShow me to the dark side ~
Long ago I tried Shell Ron 97, not good result. Immediately feel under powered. Lately tried 95, really struggle....lolThats weird, all my cars run fine on Shell 95, since i don’t have to pay for it, i have been using Shell RON95 consecutively for 2 years with no issue. Lets see how the Bardhal works on the 1jz.
maybe depend on location and how they mix before sent out to station. Around my area shell give shitty results.Long ago I tried Shell Ron 97, not good result. Immediately feel under powered. Lately tried 95, really struggle....lol
So far, got a few friends and even my mechanic mention Shell fuel not good for their cars. Even my daughter says her Chery SUV runs better on petron than shell.....lol. But Shell station have more customers, because they have more stations and many uses their fleet card. Maybe you should try Petron or BHP on one of your cars, maybe you are missing out because no comparison........hahhahahhahaPerhaps your VR is very demanding, all my engines are consider quite modernised even for the 1JZ. Even for my Volvo S60, RON95 runs just that little retarded in response but going Genting all the way uphil, not a problem.
Even my Lancer on RON95 still can run at some good speed.
haha, you also. VR on shell after 2nd tank (probably by then other brand fuel gone) starts to splutter after 3k rpm. Revs refuse to go up, off air con slightly better, so had to go back to petron.....lolmaybe depend on location and how they mix before sent out to station. Around my area shell give shitty results.
I'm good with caltex, bhp, petron.
Ooh nice nice. Should open a thread for the build progress!My mod list & shipping invoice as attached as below.
I helped a Evo 8 with this setup but had an additional resonator before the mid resonator. A special twisty type one. There are other things to further reduce drone and noise but I need to see the car space to suggest anything. The Evo had a full 3" front to back setup with exactly the same things you have except with an additional pre-resonator resonator. hahaBro i want to quiet down to 90% close to stock sound. Currently i only have a straight flow resonator, and straight flow Fujitsubo muffler. According to the modder, this setup is good for current engine setup. My front and mid section exhaust pipe = 2.5", then joined up with 3" rear muffler.
My Evo is similar setup using HKS J pipe, Trust titanium cat back, still with a mid silencer but the cat converter already removed. To me it is pretty quiet actually, no droning so no need to add anything anymore.I helped a Evo 8 with this setup but had an additional resonator before the mid resonator. A special twisty type one. There are other things to further reduce drone and noise but I need to see the car space to suggest anything. The Evo had a full 3" front to back setup with exactly the same things you have except with an additional pre-resonator resonator. haha
My VR really bad, so much so even my daughter drive say why no more power......lol Actually I have free Shell too but have to go and pump my own Petron......I pumped Petron RON100 on the 1JZ when it was fresh out from the garage, at least for few weeks. Once i switched over to RON95, i found out it slows the response a little, but still would not slow the car down drastically.
For Lancer, it runs better on RON100 too especially higher RPM. On RON95, it still quite eager to go, suffers abit loss at low end.
For Volvo S60 T4, same case as 1JZ, but low rev is abit noisy.
What to do, my free petrol is only available for Shell. Not planning to spend so much money on Petrol when i have 3 cars to hoon.
You're using all the top end expensive stuff. Fuh!My Evo is similar setup using HKS J pipe, Trust titanium cat back, still with a mid silencer but the cat converter already removed. To me it is pretty quiet actually, no droning so no need to add anything anymore.
Jom TT one of these days.Then we need to setup a meeting to discuss over this. Day by day i just drive super fast so that the engine rev past the “droning” RPM.
No la, the Trust came with the car. The HKS I got used only from my tuner.You're using all the top end expensive stuff. Fuh!
Organize loh......Jom TT one of these days.
I wanna see that boat. I haven't seen the boat before!I’ll sail over in my boat
Ok folks.Organize loh......![]()
Hi to all,
I just got a used MR-S (this is the model known in S'pore) last week.
It comes with wide bodykit, aftermarket exhaust system and SSR...
