Hello there folks,
i drive a satria 1.3 1997 model.
I have been having this problem recently.
Started when i was at a traffic light and engine was idling when is died.
I turned off AC and started the car again - it was idling ok but not like normal.
As soon as i turned AC on the engine struggles to stay alive and finally dies again.
What you think can be the problem here?
initially i thought it was one of my spark plugs not firing so i replaced them but still the same issue.
Also clear the carburator head just incase it was clogged and no air flow - but still same issue.
What else do you all think i should do to approach the problem ?
tq in advance.
Rash
edited: i realise the engine dies after putting more load on.
for eg: i tested it at night and realised the engine rev dropped when i turn on the headlights, then i tested it with the high beams / emergency lights / etc etc / .
so in other words the more load the engine gets the easier it dies.
by switching on the air cond(heaviest load) engine dies right away!
with this info : do you think the alternator is the issue ?
tq in advance.
Rash
