- Joined
- Jun 12, 2006
- Messages
- 60
- Points
- 1,508
Dear Tuner's
Recently installed LT10s X4 unit on my engine and had a problem on the throttle.
each time i want to move the car must press hard accele pedal. high rpm. if not i will stumble or stall.
THe car move but with jerking at begining... during cruising also a problem. each time a put a light pressure at accele pedal it jerk but rarely if press a bit high.
What i saw on the laptop is there was a message at status in display said 'TPS recalibrate'??
that what i saw on my pomen laptop... i'm not really understand this kind of message but i saw him open the TPS during the wiring process. Could be this may lead to my current problem?
Let say you mess up with the TPS during wiring , do we need to set the TPS to it orginal position (reset to 0v) after install it back and the reset TPS 0 position in the programme??
Hope you can advise me...
Thanks so much....
Thanks so much....
