200 whp ???
easily .
Just bolt on a bad-ass turbo la![]()
just get a set of Jun/Toda higher specs cam & valve spring, adj cam pulley, Hondata ECU, Jun 2.0L stroker kits for B16A(Optional), Jun/Toda/Wiseco Hi-Comp piston with rod set, Titanium valves & retainer set, Sard/HKS/Skunk2 fuel rail, FSE/Sard/AEM/Vortech/Aeromotive/Fuel Lab adj FPR, RC/Sard HF injectors, Jun/Skunk2/Eldeblock/PerfomerX big cap intake manifold(Or quad thro setup up), Super90/Skunk2/Spoon/J's Racing big thro, Mugen/Jun/Toda/Feel's/5Zigen/SMSP Ex Manifold, Spoon/Fujitsubo/5Zigen/HKS/Apex'i/Buddyclub/J's Racing/Amuse straight flow Ex System, Sard/Walbro/Aeromotive/Bosch big cap fuel pump, ATS/Exedy/ORC/OS Giken/Carbonetic racing clutch & the main & last thing is fully balancing with blue print & PnP header.
There r the 200whp & above on the list...![]()
WOW. RM30k to mod all this & to get a 200hp only? No wonder ppl said VTEC is expensive. with RM30k on a turbo car, it will fly...... Lolz.....
Not bolt turbo la bro. If bolt turbo, sure can get more than 200hp lo. Haha. Just want to maintain VTEC.....
Bump:
Bro,
Just wondering for all the above mention list, total roughly how much need to spend on it? Wihtout 2L stroker kit & with 2L stroker kit.
Yaya. I know can't compare. Hehe.
Thanks caleb_5375. Surely will pm you when I want to do it.![]()
dyno proven peak 201 whp/15.8kg/mm torque b16a at rpm 9500if u thinking to make 16a to 200 whp its might hard if you daily drive car local pump gas will kill your engine
81mm bore with stock 60 mm throttle body running on 13.7:1 CR will hit your target
but u have to make sure your pocket deep enough like jin says if not
your dream was far away
Tuned ny Dcloo...:proud:
