a/c problem
riezalz
a/c problem 4age Blacktop
alooo bro..
I'm using 4age-blacktop engine...got problem with the a/c..
when i push the a/c@econ button at the panel, the compressor just engage for a few second only...
and never engage anymore..
any1 can help me to solve this problem...:confused:
usually its becoz gas overloaded or wiring error. check wiring first.
where do u live? if my place at klia area i will go to dengkil beside clinic zalfah aircond specialist. very helpfull mechanic. the other one at labohan dagang, wiring man who can do wiring even u give him only engine lantai and ecu for conversion (no wiring at all). if u live area puchong, kinrara, pj i suggest u see kenny at kegani autotech. fon 03-80757411/012-6646177 taman kinrara ss3.
aloo broo..can u give me adres for labohan dagang punye a/c shop..
the ac switch blinking normally is lack of gas, oil and also the magnectic clutch got problem...
my friend juz face this problem only...
Bro,my svt also face tis prob 2,ac switch blinking.if d prob is from magnectic clutch,can repair it?or juz replace another 1?tq
hehehe.. i faced this problem twice..once is compressor kong
second time is aircon piping leak
normally low on gas also the light will blink... this is automatic cut the compressor to protect it. i suggest u go find aircon shop, check for your gas level then only u can know what is the real problem... any aircon shop will know..
what is the proper gas level? i got the manifold gauge to check it..
not really sure coz i m not into aircon systems... i juz make sure that the aircon is cool enough.. i m happy.. u can try pm bro KHWONG... his dad is aircon / wiring expert... heehehe.........
whre is KHWONG dad's shop located?
i also have prob with my aircond..
it is too cold even i set the temp to the 27
in the night journey, need to turn off the aircond sometime before turn it on again
is it my temp sensor prob?
i use blacktop aircond set.
attachment.php
knn.. u dun put me n my dad on table ok..
just ordinary ac mech la.. not expert or watever..
sometime just need time to troubleshoot the problem out.. hahah
av mech also can did it i guess...
Hi...all sifu..any 1 have idea that my car just do convert blacktop levin bzr...
After all assembly my car aircond function fail...the ac button no light showing...
My pomen tell me that is my car ecu problem but still in confused...
He already pass two wireman to check also said ecu dunno they pro or not...
Coz when I bought Halfcut tat time function well...after assembly haiz.....
Any one can recommend me to solve this problem...
Lasts few day I found a ecu board the plug in still the same problem...
I m going mad what I have do run this way and that way...
Hope someone recommend what should I do and what can I do...
Hope some kind of sifu can teach me what to do...
Thank u...
Thank u...
I could recommend Daz Garage at PJS 1, they specialize in modified Toyota cars, if they cant rectify the problem there is a aircond workshop cum wireman specialist a few door away from them. they should be able to solve it.
