4g92 NON MIVEC..
Displacement, cc 1597
Engine model 4G92
Max.power (Net), kw(PS)/rpm 145 ps (106.65 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 15.2 kg*m (149.06 N*m) / 5500 rpm
Power density 6.62
Engine type Serial 4 cylinder DOHC16 valve
Engine information
Fuel system ECI multiple (electrically controlled gasoline injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 11
Bore, mm 81
Stroke, mm 77.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.5
4g92 MIVEC
Engine model 4G92
Max.power (Net), kw(PS)/rpm 175 ps (128.71 kw) / 7500 rpm
Max.torque(Net), N*m(kg*m)/rpm 17.0 kg*m (166.71 N*m) / 7000 rpm
Power density 6.11
Engine information MIVEC
Turbocharger No
Bore, mm 81
Stroke, mm 77.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.1
4g92 MIVEC MD activate 3 or 4 piston for Fuel consumption
Engine model 4G92
Power density 6.06
Engine information MIVEC-MD
Turbocharger No
Bore, mm 81
Stroke, mm 77.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 6.2
4g93
Displacement, cc 1834
Engine model 4G93
Max.power (Net), kw(PS)/rpm 140 ps (102.97 kw) / 6500 rpm
Max.torque(Net), N*m(kg*m)/rpm 17.0 kg*m (166.71 N*m) / 5000 rpm
Power density 8.5
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger No
Fuel type Unleaded regular gasoline
Compression ratio 9.5
Bore, mm 81
Stroke, mm 89
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.3
4g93P
Displacement, cc 1836
Engine model 4G93 ECI-MULTI
Max.power (Net), kw(PS)/rpm 135 ps (99.29 kw) / 6300 rpm
Max.torque(Net), N*m(kg*m)/rpm 16.2 kg*m (158.87 N*m) / 4500 rpm
Power density 8.89
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information
Turbocharger No
Bore, mm 81
Stroke, mm 89
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.8
