6a12tt Error code 22, 23 and 31
levin818
Shah Alam
Dear Mitsubishi's sifu,
My friend's 6a12tt engine (eterna twin turbo) has an error codes of 22, 23 and 31.
I had tried search the web but just can't find any clues.
May i know what does these codes mean?
And where can i find Mitsubishi's error codes information?
Your helping hand is very much appreciated... Thank you!
CODE
ITEM (from 6a12 mivec-fto) should be same to urs
11Oxygen Sensor12Air Flow Sensor13Intake air temperature sensor14Throttle position sensor15ISC Motor Position Sensor21Engine coolant temperature sensor22Crank angle sensor23Camshaft position sensor24Vehicle speed sensor25BARO Sensor (listed as 26 in one info source)31Detonation sensor32Vacuum sensor36Ignition Timing Adjustment Signal39Oxygen Sensor41Injector system42Fuel Pump43EGR44Ignition coil and power transistor unit (Cylinder 1 & 4)52Ignition coil and power transistor unit (Cylinder 2 & 5)53Ignition coil and power transistor unit (Cylinder 3 & 6)55Idle Air Control Valve/Servo Valve Position Sensor61Communications wire with A/T-ECU62Intake air control valve position sensor64Alternator FR terminal71Vacuum control solenoid valve (TCL)72Ventilation control solenoid valve (TCL)
