......so sad lah have to use back ori ECu now but luckily installed Superchip before install back. Although its not as cool as the Haltech but also still can work better than the original...:DTitanRev said:So shit lah...yesterday my Haltech kong already......so sad lah have to use back ori ECu now but luckily installed Superchip before install back. Although its not as cool as the Haltech but also still can work better than the original...:D
TitanRev said:ITs for E6k i think for controling the fuel and ignition wan...
yesterday morning when want to go to college that time...i just put my car key in then try to start...suddenly, here a very loud PAK sound...then check battery pecah already luckily the acid inside didnt leak out...so change a new battery in which i kept in my store room...then try to start again...got current but cant start and got some funny smell from the passenger side where i put my Haltech...when go check...SHIT loh...burnt smell coming out from the Haltech.....I was like DIU loh....Dont know can replace a new 1 or not...cause i think still under warranty...
TitanRev said:NOt Ek6 lah...bro. Its the name of the Haltech ECU...:D
If i got an EK then i will sure be very damn happy loh...will drive the EK everyday and leave my 206 at home...only drive it during weekends..
et5828 said:titan
i need some info bout ignition
the mechanic told me to go back to p2 to set my ignition timing higher like 3-5 degree
what ignition timing for?
he told me after set it higher my car will be faster cause i'dready installed cam
how do i know the rite degree for my car?
TitanRev said:I'm not quite sure how to explain...izit ur car idling very low ? If u mean by adjusting the cam, maybe he is telling u to adjust the valve thing..
maybe like set ur inlet vale to open ealier before the piston reach TDC..and those overlap things...you have to know the original setting of the valve 1st then only you can made adjustments to the cam..if not things will go wrong...
This job is better left to the pros to do it...you have adjustable cam pulley ?
johnson_goh86 said:hahaha.. i think u`re running lean ler.. not enuf fuel... have to mod the fuel lines... where did u do it? matspeed? if yes.. then u need to mod the fuel lines.. read it in k2oc.. u go read up for urself la.. done b4 by kelisa187 if i`m not mistaken...
