mh wong
possible
Maybe your clutch slip at high rpm?
Can just off the air con and try again, and more over you should off the air con compressor when doing high rev. Firstly you will get more power, and secondly you will save the compressor on the long run. Air con compressor running on high rpm may not last long....i think i should check the air con gas pressure as i just serviced the air cond last week .
throttle body i just serviced few months back. anyway i will get this two things checked.
If clutch slip, then his RPM will go higher, but speed slower.....
so i guess its definelty not clutch slip
---------- Post added at 08:52 AM ---------- 6 hour anti-bump limit - Previous post was at 08:48 AM ----------
tried with air cond off , same only .
and i realised this problem is not consistent , kinda on and off.sometimes ok
sometimes cannot go .. :hmmmm:![]()
y not check wif this pomen, Ah Fatt 016-292 0668, Damai Perdana
any update regarding your issue? Would like to know the problem too
if you have check almost everything,try referring to its original source.RPM is when the crankshaft rotates.check the crankshaft
Interesting, what will be wrong with the crankshaft?
