Seems u have problem with caliper uneven wear off. Dun skimmed ur disc too much (most skimmed disc done also not balance), overhaul ur caliper remove all dirt, replace new caliper piston seals n new brake pads.
Taikor…ur steering vibrate when u step on the brake? Which part of the rubber mouting u referring to?ler said:already check
finally it coz of my top rubber mounting of my front adsober were tears
change it n now in no more shacking
thanks guys
Then how about the disc? Do I need to skim it?kaminari said:Seems u have problem with caliper uneven wear off. Dun skimmed ur disc too much (most skimmed disc done also not balance), overhaul ur caliper remove all dirt, replace new caliper piston seals n new brake pads.
thanks guys
siangmh said::_: Good to hear u solved ur problem
Change both abs' top mounting right? How much? material & labor?
auragtti said:Maybe your stering rod cupling or stering rod bearing???:X-:
