the problem is that at TDC, the VG pistons is not as the same height as the block deck (VG pistons actually lower than the block). have to skim the block a bit to make it same height as pistons @ TDC. if use stroker crank can la.
the cc increase is due the larger bore but the stroke still the same when retaining the same crank & con rod.... normally the block need to be deck around 1.3 to 1.5mm depending on the user request.. this will effect the compression ratio of the engine.
The compression high of the VG and Toyota piston that mostly used in VR4/EVO is lower than the VR4/EVO piston compression high.
I hope the owner of the cars doesn't mind me putting their rides up in my blog. But I thought of sharing some of the pics from a great evening out in town.
But sorry....u have to go to this link. Very the malas to...
hi there ppl, have a pair of used OEM front rotors and caliper to let go(last i used it not warped), asking 150 bucks(firm) only as its taking up space and bloody heavy, anyone wants it just give me a call. 017...
A friend of mine recently obtained a V-AFCII with a MIVEC converter for his 1.6Mivec. DOes anyone have the wiring and basic configuration for the V-AFCII?
I have the standard wiring diagram but this does not include...
