Hi D7zul,
yea i've tried that before and my mech said that its not advisable, as the air intake wouldn't be even. so it makes the 1st throttle to work more than the rest... not sure ...still noob...
d last time i tried the trumpets on, my car performance dropped drastically. Acceleration was like crap, so i removed it immediately. I think you need a bit of tuning after installing the trumpets to get the most out of the 20v?? I know mine performs worse than a 1.0 kelisa..just by installing the trumpet without any tuning.
serious?!!
i've been having problems to start my car in d morning.. always cranks 3 times to start..
after i take out the trumpet.. it starts at 1st crank..
is ur mech using a 20v???
:hmmmm:
). So If you like linear response, from 4k to 8k, then stick to stock trumpet. If you wants more acceleration after 5k, then you can consider the after market trumpet with diff length. But as your know, once you selected a short trumpet that resonance at high RPM, it mean your low RPM will become turtle. So choose it with purpose.Stock trumpet, won't affect morning start mood le. I always first crank then "up"..
Check following possible areas of your morning mood problem:
1) Throttle opening screw setting is out
2) Throttle opener faulty
3) ECU
Anyway, to add a little about the trumpet... diff length of trumpets resonance at diff range of RPM. For more details in theory, check with Acoustic Chin (who already missing fr zth for long time). So If you like linear response, from 4k to 8k, then stick to stock trumpet. If you wants more acceleration after 5k, then you can consider the after market trumpet with diff length. But as your know, once you selected a short trumpet that resonance at high RPM, it mean your low RPM will become turtle. So choose it with purpose.
Not to forget, same goes to type of exhaust. Always compliment both, intake and exhaust.
i think this setup is more powerful..
