So, practically everything short of turbocharging?
Well, sort of. Fuel injection la. Carb would have more to play with but I know nothing about carbs.
Tell me more! I'm curious.
Create your own thread on modding a 4G15 or talk at the 4G15 mod thread la.
Issuzark... change to manual tranny lah hehe
You see this --->
If I'm sifoo you are SIKUNG ok.
hello sifu sifu
my iswara 1.5 auto acting weirdly - morning when drive to work the gears very hard to shift
its like keep over rev until almost red line only sudd u hear the pop sound and enter next gear
but during afternoon seems normal super smooth , isit my gearbox giving signs of times up ??
For morning drive, after car have warm up still the same, means change at high revs?
After the engine gets hot enough to normal running temp , the gears shifts 3-4k rpm :hmmmm:
when cold start and drive , will be 5-6k rpm if u tekan the fuel pedal more to force it to change then fly up also to 7k rpm only sudd knock in change gears
the Atf most probably few months ago due to gearbox keep leaking , then went to fix and top up new ATF , the prob is when cold start then start driving it very slagging like turbo lag
I know the engine need top overhaul due to eating engine oil , and the exhaust pipe keep coming out water and sometimes white smoke
Since only in the morning when it is cold, could be the valve or atf. If not going to open up the gb, you can try some atf additives first. Some recommend K&W Trans X, some use Lubegard Platinum. Some good feedback from users. This may or may not help you, but can give it a try.
Exhaust got water in the morning is a good thing, but white smoke is not...:rolleyes:
