Don flooring mean, not everytime ..... not every traffic light/toll. Is ok, You can swap 4g93t.
Gov still allow 1.8 swap...lol.
1st and 2nd gear ratio short. Cannot tarik...
1st and 2nd gear ratio too much power.......lol![]()
4G93T originally tarik 4wd......However, cars converted with 4G93T tarik 2wd at the front only. Power only concentrated at the front, so most likely the front mount of the car develop cracks.....esp when whacked frequently in 1st or 2nd gear.
Back to discussion of old school cars... Do you think these old chassis can handle the power of newer engines like maybe a 4A-GE 20 Valve on a TA22 or KE70?
Old chassis, if rusty even worse........lol
If go for those chassis strengthening services, effective or not?
Old car such as TA22 (earliest should be 1971, I think) is already 40+ years old. Provided the car is rust free, and retained original chassis strength, standard 4AGE engine is already pushing the chassis to its limit (assuming the driver is using every hp from this standard engine)
Before even considering chassis strengthening, perhaps one should tackle the rust problems.
Japanese old skools are often associated with rust issues.
I think it does not help, as most of the time is the welding that cracks.....
I saw a TA23 long nose with a 1jz engine. Lots of mods involved, The engine has only mm space before firewall, and few mm from the radiator and shroud. If the celica had a moderate front impact, the engine bay is gone....The wasnt any crumple zone to absorb the force. Donno if that car had JPJ endorsement or not....
I suspect the car is nose-heavy if plonked in a 1jz.
For me, a 4age powertrain or a turbocharged version would be sweet for the celica....Price wise.....:rolleyes:
If any watch astro discovery. Those restore old car/truck,
only use back exterior built. To look as old skool. Structure beneath it already replace with new frame.
Here if Don't legalized then can loh......hhahahhahah
Last time NTV7 also got similar show years ago. Called Overhauling.
Changing frame is totally not allowed here. Touch chassis a bit also can't.![]()
The thing in Overhaulin they have chassis parts also.......lol
From time to time, there are monster car sold at mudah. I checked a few cars out, and quite surprised they are driven on the road without endorsement. Of course, most owners assured there wont be prob when changing ownership....
That one if buy, must make sure can transfer......lol![]()
