- Joined
- Aug 28, 2008
- Messages
- 35
- Points
- 1,506
can consider saga.
can consider saga.
If new cars, Saga, Kancil as well as Myvi(the cheapest model around 32k onli if not mistaken) also at that range.
Buying second or first hand cars is depends on your budget and your support especially salary to fix it..
If second hand car is your choice, u need to prepare money to fix some minor and some major problem or sometimes sad to said that use 1 year need to spend thousands on overhaul the engine.
U dun need to waste that kind of money (that means safe at lease for 2 -3 years) for first hand cars somemore got warrantee for it also..
For Saga will be a good choice also coz that car is suitable for family use (i mean normal daily use) Power wise so called ok onli (dun expect that your car can fly will low budget..hehe)
Petrol wise, of coz will be higher compare to its class coz the exhaust is direct flow..
All will be depends on you coz if u dun like that thing, no matter how good is the thing will also called as bad coz u dun like it and no matter how bad is that thing, as long as u like it, u will said it good...
GOOD LUCK!!![]()
