6a12tt-rs.perdana v6
the GSR piston is from what model LANCER E-CD5A or E-CM5A(enjin terbalik)?cozz 4g93t CM5A(terbalik)the compression ratio is 9 but the 4g93t CD5A comperssion ratio is 8.5
cannot, cos evo pistons are too big,
std 6a12tt pistons are 78.4mm, can only rebore max 2mm.
4g93t piston is 81mm. so should be safe.
now i'm already upgrade the engine....now i want to upgrade the standert ETERNA 1.8 manual gearbox any advice....?some people says ROJAK the gearbox with EVO gearbox.... :hmmmm: plzzzz...
hmmmm...good idea.....but what i heard is that eterna gearbox is using 8.5 inch...now i'm to change to 9 inch....it could fit...?
code 222, 232 from eterna 1.8 & 2.0 is 8.5"
if 312/332 eterna v6 n/a & TT is 9".
if u using 8.5" now but wanna use 9" flywheel i think kenot la bro....
the gbox housing kenot fit.
what is your advise 'ROJAK' the gearbox or change the gearbox....:adore:
using sei engine with manual tranny isit?
sei can use evo3 manual gbox set.
for v6 can use
1.222
2.232
3.312
4.412.
for eclipse or wira diesel, u only can use the internals, as u need to use back original eterna manual gbox housing.
Danz...i'm using the RSM how much limit speed for TT..?i'm setting bout 195km/h only...now i'm think to up the setting bout 250km/h....there is any trouble when i'm setting that much..?
i think the max speed for std tt that one of PPC member had clocked in at 256++kmh.
function of RSM is to remove speedcut. if u wanna set @ 190kmh must as well dont use rsm, cos ori speedcut is at 180kmh.
