DIY GROUNDING
can we used the boost cable /jumper cable as grounding wire
i think is big enough is it?? :lol: :lol: :lol:
200a or 400 a???
but is it as good as the wire used to grounding or better than that??
car engine will eventually kena water 1 mar, especially when send the engine go to wash right?
hey guys...i just diy the grounding yesterday when i send my car to re do my ice wiing...i use the old 8 gauge wire which is used to be my power supply to the amp to do the grounding...thx 4 the info...but didnt feel anything lah..hahahha....but good thing is tat...i diy it hahhhaa
ur car is new car kua...... :P
feel nothing on performance, right??
Hi guys, i have a question. What if the battery is located in the car boot ? The ground wire must attach to the battery ?
Originally posted by JINEIL2EN+Dec 10 2004, 08:44 -->
QUOTE (JINEIL2EN @ Dec 10 2004, 08:44 )
--QuoteBegin-Yong_5290
@Dec 9 2004, 21:12
ur car is new car kua...... :P [/b][/quote]
my car is a wira onli..year 2000...
ksgoh...i dun feel anything tho....i connected to alternator..body..valve cover..battery...distributor...correct?
sometmies it works on new car sometimes not. i also wonder why, my kelisa feel more power on electric after i grounded it ... it's 2004 car somemore ..
went eneos yesteray, they do selling back the grounding wires, RM58.90
5 points ya ~
1 thing i feel tat is my ice system has improvement in some way....like less noise...
5 points ya ~
wah so cheap!
mine made the bigest difference is engine block.....actually same effect as puting on engine coverlahh
5 points ya ~
hey dude, u DIY install de ground wire or they install for u?
any installations fees?
I DIY for it .. it's fun to do it ~
YOng_5290 : that's for sure and cuase my mid speaker crack already .. heehhe
i think you need a long wire connect from your battery -ve terminal to the car front body.... and from there you just ground all the other grounding wire to there.... just 2 cent.... haha :D
Originally posted by tykoh+Dec 13 2004, 08:29 -->
QUOTE (tykoh @ Dec 13 2004, 08:29 )
--QuoteBegin-Anticlockwise
@Dec 11 2004, 00:56
i think you need a long wire connect from your battery -ve terminal to the car front body.... and from there you just ground all the other grounding wire to there.... just 2 cent.... haha :D [/b][/quote]
OH NO~~ what if i only attach it to my engine bay without connect it to my battery ? last time my car was like sh*t, once turn on the a/c the car lost power, even u step on the pedal 9 9 also the car won't go. Now i have 1 ground wire "thick 1" connected from my alternator to car's body (not connected to the battery coz battery at the back), i feel big difference especially when i turn on the a/c, no more power lost n jerking. But after i installed my ICE back i feel power lost again whenever i turn on the a/c (but not as bad as b4 grounding). So guys i need your opinion, i wan to put on more ground wire to the car but is it necessary to connect it to the battery ? is it a must ?? by the way mine is old car, some ppl don't feel any difference after grounding b'coz the car is not old enough :lol: .
so sifus plz help~!!! need advice~!!!
you can ground to ur bodyearth(from battery -ve - rear boot) . then at the front, from ur bodyearth and link it to alternation, distributor .. and so on.
maybe? can try. i think no need a long wire from the boot to the front..
i think my battery -ve has already grounded to rear boot body, no wonder it works so well with only 1 ground wire at the alternator... gotta double check later... thanks shong ;)
@Dec 11 2004, 00:56
connect all the point u want to be grounded to one point (at front bonet), then connect the one one to ur battery at rear boot.....this will save a lot of grounding cable....
anti, i got the same prob wif u also. seems that after groundin , the car felt heavier. and i got shocked twice today. (finish me grounding yesterday)
Points grounded:-
1) engine block
2) distributor
3) fire wall
4) car chasis(near battery )
5) connected to -ve battery
Yet to ground:-
1) alternator
2) gearbox
3)anymore place to ground??
what did i do wrong? I used the steel lug instead of copper? would this lug last? I mean since the engine compartment is so darn hot..!!!
pls help n advise...
