nice putra..thanks for the response..neway just wanna ask u whether u know nasrin drive satria gti..coz ur spec almost the same with his..n i supposed his car,but i bought a putra instead...really regret for not buying his car last time..
Spoon))) said:nice putra..thanks for the response..neway just wanna ask u whether u know nasrin drive satria gti..coz ur spec almost the same with his..n i supposed his car,but i bought a putra instead...really regret for not buying his car last time..
spyderslr said:niceputera: so u r from ipoh....?......i only goes bak to ipoh once in a while....actually i have limited knowledge on valve angle jobs....would like to know more tho....cant really seem to understand the function of doin a valve angle job and also how its been done......do u Port it....?...or Polish it....?...or reshape it to various angles...??.....hope u can enlighten me abit....thx....cheerzzz
niceputera said:My answer:
1) Both are good. Satria 's will be safer in terms of timing setting. Mivec's will need you to careful a bit and are prone more to knocking. Whatever u do, try not to exceed 12.0:1 CR. Generally, that is the limit of Ron 98. OEM Satria piston has several designs as well. Look same but it's not. Choose wisely.
2) J5 - u need to refer this matter to Matspeed. My personal opinion it cannot be done. Not necessarily to use J5 - e-manage, Unichip, Smt6, Obit are all good. Just find a good tuner to tune it for u. A piggyback / standalone is only as good as the tuner - if u get what I mean.
3) I'm not sure about the fuel pump capacity. But in general, if u do not increase the std factory fuel pressure level, than it still can withstand the increase in power. Fuel pump max. operating capacity is highly depending on the fuel pressure. The more pressure being applied, the less max HP it can withstand. With std setting, '93p fuel pump can support up to 300bhp power.
MY advice, do not change it yet. U (or ur dyno operator) will know when the is shortage of fuel from the dyno reading. 1st thing to do is to change the injector to 1+ size rather than to go for the fuel pump (assuming u can mod ur car to more than 250bhp if not leave it alone :regular_smile: ). The factory part is quite good already.
4) No benefit, just concentrate on the REAL things.
5) Ratio 1-5 same as SGTi/Putra/1.5. Final drive I'm not sure. I've forgotten. Maybe somebody else can help.
Rgds.
Spoon))) said:wah..a lot of information la this thread.. really good la...satria81,we are in the same boat..i just bought a putra and planning to modify it..after reading this thread, i can finally get the picture on how to mod my car,coz it totally different from my last car which was eg..
niceputra,can wanna invite u for a drink or two la..wanna gain more information la..
rgrds
llsaw said:Hello Niceputera,
Good to hear another member from the Matspeed club. How is Charlie doing these days? Do join me at http://thespfiles.blogspot.com/
satria81 said:niceputera,thanks again for anwser's for the above...im pretty clearer now on it,very much actually.
niceputera said:That is why I'm here, to share with friends. No point just keeping it to myself. We share the same interest - car modification. I'm looking foward to hear from others too so that I can learn new things.
llsaw drive putra :)niceputera said:Charlie is doing fine. Just have a chat with him 3 weeks ago. He is full with new ideas. He is doing something new with '93 engine. Still in the R&D stage but hopefully successful.
U r from Penang if I'm not mistaken, right? SGti club member right? I'll join u. Thanks. :regular_smile:
V8_nutter said:Niseputra,,are u using MAF sensor ?? With your spec, i beleive you can bump more horsepower with a Microtech MAP wirings:regular_smile: perhaps can gain at least 15hp more. Do you mind sharing with me your cam setting,,how many advance and retard you run on the intake & exhaust ? what is the power like,,,more to midrage or top end ?
1 more thing,,,you get that tourque figure with 4g93 intake or GSR intake ? any port doing on the intake itself ? wanna share.
tkkhoo said:llsaw drive putra :)
True. :regular_smile:satria81 said:id be happy n only satisfied if i can get the power delivered with reliability.....yeap RELIABILITY ,its seriously a important factor esp in a car of daily usage
