Raising CR will give you a power gain provided you don't encounter pre-detonation. And the power is at all most rev ranges not at the top end only. Popular theory states 4% power increase for every 1 point of compression increase. Raising CR and the power effect is not dependent on the cams. In fact it is the other way around. Big cams require higher CR else you will lose power.
