V8_nutter said:It's just a crappy talk lar,,,someone said,,,mechanics said,,,some alien said. I think after this someone can claim that 2.2 litre pistons and 2.2 litre stroke can plonk into GTI block,,,,i wont be surprise then:angel_smile:
skycx said:spyderslr
Senior Member Join Date: Mar 2004
u mean stroke zit.......mind telling us how to stroke a 4G93...???.....83mm can go in, but how reliable will it gonna at the end of the day dude..??....
ya... stroke ....ori is 89mm n change to 94mm
i only heard from the mechanic
boyzone said:This is basically what I see on magazine how is people mod on 4G93.
1. hi cam RM2k
2. cam pulley RM500
3. sub ecu (Piggyback) RM2k
4. intake/outlet upgrade RM1k
5. upgrade internal parts ???
6. fully engine balancing RM2k
7. flywheel + clucth
8. port and polish RM1.5k
9. fuel system
10. increase compression ratio (will increase depending on the setting of the CAMS and the skimming of the head)
I think overall will cost u around RM 25k ++and will gain around 155whp
spyderslr said:u mean stroke zit.......mind telling us how to stroke a 4G93...???.....83mm can go in, but how reliable will it gonna at the end of the day dude..??....
CARENT said:bro, I think tht I wouldn't recommend tht. Better stick to the stock size if there is nothing wrong. Because, anything done, cannot be reversed. Just stock to the changing the standard to aftermarket (with the same measurements)
Cheers.
Cheers.
satria81 said:Engine_Maniac,
I appreciate your help & concern truly, I wud not go after such suggestions.....:).What do u think of a skimmed flywheel compared to a non-skimmed,as in the disadvantages n advantage?pls advice, thnx
yswong67 said:WIL MIVEC WIN V-TEC?
Ans: Never till the end for stock to stock, v-tec jus like an add-on turbo to it n mivec none but to add other parts to win v-tec.
Mivec advantage are most parts can do some adds for this engine to push the power, but v-tec even change the ECU also can win already. No point for mivec!
Pls don angry for the mivec fans, I jus telling the truth.
even sr20de also cant! (silvia)
