Hey bros,
i drive a 9 year old Wira SE (first batch). may i please join this community as well?
I actually have a question..Why is it that my car can't exceed 150km/h?
I have a k&n drop in filter, Bosch Super Sports Plug cables, I use Torco Sr-1 Racing Oil but yet i can only touch 150 max. I have also recently done a top overhaul but i still face the problem. Is there anyone who can suggest what i can take a look at to improve this because i saw videos on youtube about ppl touching 180-190 on their wira se. Any recommendations apart from engine transplant will be appreciated.
Wei! when trying out your Trestor Blue Advantage.....Anyway, 150km/h sounds like you're using auto with stock exhaust. I've done 180 on my SE a long time ago and with auto, but I had my engine heavily modified. I haven't bothered to try anymore now that I'm on manual because I know stopping will be damn difficult even with my uprated brakes. Not willing to risk my life to find out.
When I get my caliper separator tool to deal with the rear calipers. Using the long nose to twist it in is so tiring la. Wait la. My Bendix is wearing out also mah.Wei! when trying out your Trestor Blue Advantage.....![]()
4g1series...Save the Brakes...![]()
any suggestion / idea is much appreciated
. Tqsorry guys, but this is out of topic; need help... a few of my AEM F/IC6 flying lead harness wire have came off the socket connector, and I don't have any idea on how to put it back into the socket, which inside it contains a clip. Anybody know how to fix this or shop that I can send it over? Attached is the example of the harness, 22 pin and 24 pin. I got the socket pin diagram.
If I know this would happened, I would have glued it...any suggestion / idea is much appreciated
. Tq
your location? maybe i can help u sort the wiring (if only the diagram clear enough for reference)
i'm in seremban btw...
, currently i have send it to my friend ( the nearest, we're both in KL). Hope he can fix it. If not, i will revert back to you... but again, tqvm. :top:
hello:wavey:
another 4g15 reporting in.
Anyone has pics of 4G15 installed with oil cooler and oil temp and pressure gauges?
