Bro, I 've got no idea on CAMPRO engine. But to confirm it, U need to check on the Bore(diameter) and the Stroke of ur engine. Because those are the things that determine the fitting.. And most importantly, the method of holding the piston onto the conrod and the diameter of the piston rod. For example, Mitsu uses force fitting piston rod, toyota and nissan uses clips.
can. But u need to bore up the block to 81mm. Then U'll have 1.6 instead. Some ppl said max boring is 2mm in diameter... Not for this case... because the block configuration is exactly the same as 4G92. I have a friend already done it and turbo charged the engine.
hie guys. im looking for a R33 GTS-t as per title :proud: if anyone knows anyone selling or come across it somehow somewhere :hmmmm: do post here and lemme know? sorry to trouble guys.. thanks a lot!
What is the standard boost for the 4g63 engine in the Evolution 8? Is it 1.2bar or 0.8bar or lower? Is there any boost differences in Evo 7 , 8 and the MR? Like the 4g63 engine, is it possible to change...
