bro...what u can do is..check ur air con system first...if ur car is idle and the gas pressure shoots up..means ur compressor going alr..
next..go get those halfcut el cheapo denso external fan...for our cars...evo3 external compact fan will work..install it in front of ur cooling coil (and ur cooling coil is right in front of ur radiator)
that will do the job...at least help a lil..proven la...
Bro agree with you using the fan cheapest way to solve problem...
Germ im not good with aircon but you made me more confuse now... what i highlighted i thought it was the condensor infront the radiator??? cooling coil located inside the cabin just before the blower right???:hmmmm:
Have replaced complete float unit (brand new from Wing Hin) still...
