I've seen a B16A built using TODA parts ( stroker kits, titanium retainer n valve springs, valves, head bolts, cam gears, cylinder sleeves, balancing etc. etc.. ) revving up to 12K in a drag race...well, tats what comes with deep pockets ;)
now i know what u r saying... tq mr arta n signal... good xplaination dough... ;)ARTA said:Bro hattech-v, like me n bro SiGNAL mentioned in the previous page, by changing B16A piston to B16B piston, u will get CR same wif B16B's which is 10.8. The capability to high rev...maybe the lighter CTR crank would do the trick. Difference between B16A n B16B's head...it is said tat the both head are basically the same just that B16B received minor porting job by hand ...like the B18CR head, been ported...actually is the same with the B16A's. Its been tested that the B18CR head shows identical charateristic with the b16A's just tat at certain range the B18CR had got slight difference.. I wasnt really sure bout it..
wahhh... mr arta using 84... must be sifu... me using 81 for a long time... till now standard... even steering also standard... wanna b like mr arta la... mr signal using wat ehh...?ARTA said:Bro zamrioo: U r welcome ;)
Bro ADVAN: i think it shudnt be problem providing that u do cylinder bore and proper honing. I was thinking to use TODA's B20 high comp 85mm piston like those selling in AMOIL, only when i got by block sleeves and the budget for a proper block job. Otherwise, i'll just stay 84mm..
